regarding reg 522.6.6 part v, its ok to have a cable just under the plaster so long as its in a safe zone and is protected by an RCD (522.6.7)Im not quite getting that, after all Joe Public doesnt know about safe zones does he? yes
Also if the cable is buried deeper than 50mm, does that mean that you neednt bother with any of the protective measures called for in 522 if you are so inclined?yes
Could I theoretically have a cable running straight from an MCB, that meanders all over the wall to an accessory so long as its buried 2 " deep?yes. but if you do manage to chse 50mm into the wall, you will most likely be less than 50mm from the other side. and more importantly, the wall could eb structurally unsafe
If I was hanging a heavy mirror, id probably drill more than 2 inches deep to put an anchor bolt in
