matt.leung
i popped round today oo see a new client that is having a loft extention. The builders wil not go any further until the electrcis done.
They recently has a PIR done and i was reading over what needs to be done.
Because of where the fuse board is located which needs to be upgraded anyway, the only permitted route from the consumer unit to the loft will be surface mounted, as they have newly decorated and will not allow any chasing.
The client want me to come straight out of the consumer unit, thorough the front wall into the porch, and then straight up using trunking. For here upwards is easy, but i am not very keen at all about running cables outside up the wall in trunking, even though it is a porch (open porch).
the cables to be run is the loft ring and a new lighting circuit...
can i please have some advice about the running the cables in mini-trunking.
Would BC pass this or not...???
matt
matt
