smithjim0001
- Jan 14, 2010
- 23
- 0
Hi All
On inspection of any ccu am i to understand that it should be noted on the test sheet that the tails should be 25mm obviously most installs that are a little old will have 16mm or less so should this be noted as undersized incoming tails.
Also regarding searching for the main water bond if it is there but cant be found ie behind cupboards how far do we go and how is it noted on the test sheet.
Thanks All
Thanks All
