could any body help with these ?
a transformer is rated at 10kw but is only delivering 9.8kw.copper losses are 0.33kw and iron losses are 0.2kw. calc the efficiency of the transformer.
a transformer has 400 turns (pri) and 200v(pri) it produces 100v(sec) with load=10ohms. calc current(pri)
determine the resistance of 100m of aluminium conductor.csa is 120mm.use the resistivity of aluminium =2.84x10-8ohms
a 10 microfarad capacitor is connected to a 240v 50hz supply.calc the capacitive reactance ?
calculate the total resistance (rounded up value) from the following information - 100 copper cable,1.5sqmm with a resistivity of 17.5x10-9ohms
will this keep you`s going for now. just going to the fridge for a beer !!!!!! :Y :Y
