Hi guys as I’ve already probably said I’m not from a domestic back ground but wanted to know how you guys go around certain things. My questions are:
if you was fitting a new board and breaking the current installations tails to install new tails would you then have to correct the current tail (if they was fed through a cavity and not RCD protected is it then your responsibility to correct this and would you also have to test every circuit in the installation as you’ve modified the tails)
another one I’ve wanted to ask is for all the guys that do call out what do you do if you come to a job that you are asked to sort out say a circuit kept tripping and it was a loose connection etc. say if you’ve sorted that out but the circuit isn’t up to standard say ZS isn’t compliant or bonding conductors aren’t sufficient. What do you guys do fill in a minor works or a danger notice? I’ve always wondered what you guys do as there’s lots of installations that have been ‘working like that for years’ but when it comes down to our responsibility what should we do in these cases?
