Hi
I need some advice on this one. In a kitchen that I am working on there is a siemens 7 kw hob and two siemens 3.6kw ovens. There are two 6mm cables that are run to the area of the ovens and hob. one of the cables I am going to use for the hob on a 32amp mcb.
With the other 6mm cable I was wondering if it was possible to load both ovens from it on a 32amp mcb, cable calcs show this is sufficient for the cookers but would this be acceptable when getting tested and inspected.
