Problem solved! There was a connector trapped under the air filter which came from an auxillary fuse box in the engine. Found an old drawing which labeled all the connectors at the main fuse relay board. Had no power there so chased it back to two brown cables thought the engine bay and when I gave it a tug to see where they went and it came loose!
Thank you all for help and suggestions. Has been a steep learning curve for me
