Hi all this is my first post so please bare with me!
the other night i was called out to a job where a shower was tripping the main rcd, the phone call was sketchy but went out anyway. it turns out that an other electrician had set up an 8 plot caravan site. each plot has its own 16amp rcd and meter. the couple in question have decided to buy an old porta cabin and put it on site instead of a caravan. it has in it a main fuse board with light ciruits heaters water etc and a shower. someone had connected this board to the 16amp board outside and hey presto when they turn the 40amp shower on it trips the 16amp rcd outside!
so i know caravan parks are limited to providng a 16amp pitch and on some sites lower at 10, i have checked section 708 and 721 in the regs book but not really found an answer, can i legally change the 16amp rcd for say a 40amp rcd and install a suitable swa cable from the meter to the porta cabin so they can run a shower?
the site is a private one all the residents are permanent, the other 7 are in caravans but i think they all intend to buy some sort of static home in the near future. so will all face the same problem but this is a new one on me!
i hope you understand the question and someone can help.
many thanks dan
many thanks dan
