ianroycroft
hello
i have a 33amp/hr (does that make sense it says something like that on the box) , i would like to charge it using the car cigerette socket
the charger has a plug thats output says "16v 480ma" but the cigerette outlet is 12v. The unit lights up and appears to be charging, my questiin is will it charge okay while the engine is running, or will it burn out the circuits even tho its less volts but more amps
also is there a device that will let mecharge the unit safely? like allow me to choose 16v for output at 480ma
thanks in advance
i should say its a car booster /jump battery device
thanks in advance
