plus, its a real ball ache to use and fit, :shakehead
howd you manage your free upgrade then?
I dont think you can actually get cat5 anymore, it was the standard before 5e [enhanced] came about,Cat5e and 6 will both run 1Gbps at 100m if installed correctly, Cat 6 will have better headroom. Cat6 or shielded would be the better option if your distributing HDMI etc over it..
I don't know where Ash is picking up Cat5 (I presume he means 5e) for 5p a meter, if he is then I expect it is CCA cable with I would avoid like the plague. CCA cable might work on day one and with it you can have problems with Poe.
If someone wants to put in fibre - you can always get pre terminated!
