Flexible cords, non armoured...25A protective device on a xlpe 2.5mm 3c ?1.5mm 3c flex how many amps max ?
you been hanging off it again specs :^OFlexible cords, non armoured...max current?
try page 296, table 4F3A
1.5mm copper flex, 16A.
(& could support 5kg weight])
cheers SLFlexible cords, non armoured...max current?
NO not rated for three times ccc! just rated for higher temperatures e.g.90 degrees rather than 70cheers SLQ.
tri-rated cables is the term tri because they can carry 3 x times the current?
