Certification
Bez
Nov 1, 2009
525
Got a small job to remove 2 pendant fittings and replace with 2 surface mounted spots on a brand new property. Non- notifiable I know. Will still test the circuit prior to commencing but my question is, does it require a MWC or if not, do you guys issue one anyway, even if it's just to record results?
Cheers
Bez
Its more than likley going to be a cash job, don't leave a paper trail, unless they really want on.
Got a small job to remove 2 pendant fittings and replace with 2 surface mounted spots on a brand new property. Non- notifiable I know. Will still test the circuit prior to commencing but my question is, does it require a MWC or if not, do you guys issue one anyway, even if it's just to record results?Cheers
Bez
Are you registered with a Part p, scheme provider yet?
I know with regard to this work it is irrellevant...
BUT....
at a later assesment date when they are looking though your paper work & copies of issued certificates, A few easy-peasy MWC's can help bulk out your filing and help show that you are issuing certificates for ALL work not just major stuff!
To the strictest letter of safety & regs & stuff you would still need to verify polarity & earth continuity at your replaced fitting!
Bottom line.....
If youre a bit short on MWC's in your copy of certs files.. Issue one.
If you are OK, toss a coin.. heads you do, tails you don't! ; )Guiness Drink
Generally I will test to ensure its all ok but paperwork is a pain so unless customer really wants it for a small job I won't.
Batty
Are the spots ELV? If yes, then it is notifiable unless they're complete units.
