hiayushman
- Jun 21, 2012
- 8
- 0
Hi there!
I'm building a circuit and having a little trouble while setting up a 3V solar Cell(~100mA) in the circuit as attached.
When i tested the solar cell the open circuit voltage was above 1.8V but while connected in the circuit, it just aint rising anything above 0.75V. The battery voltage is 1.25V while the led has a forward voltage of about of 2.8V.
Is the battery charging if the solar cell is put in light?
It is to be noted that the 22K ohms resistor isnt working in my circuit, so i have replaced it with a 500 ohms resistor. It sets its sensitivity to cut off the led if it is placed in ample amount of light. The website from where i took this idea says the resistance should be of high value, i.e., more than 15k+ ohms but in my circuit it only works for 500-1K ohms resistance. Any suggestion?
