Just to add I spose there are three most common sort of chase's
(ignoring horizontal chases!
1/ Vertically 'down' from a socket to floor, (behind skirting), to under floor void.
With these I often use an offset chisel thing like the one that Ian linked to,
for getting behind skirting boards.
The short bit of chase to the socket I tend to do with hammer & chisel..
(unless it has all fell off during the back box sinking cuz the plaster was carp anyway!!
2/ Vertically 'up' from a socket, such as concrete floor properties, maybe some kitchen applications.
Cuz these are a longer chases, typically needing 2 x 2.5mm's to be buried and maybe a bit more depth into the brick work if the plaster is a bit thin.
So a bit of power tool assistance may be needed rather than just the ole hand tools.
3/ Vertically 'up' from a light switch to ceiling, (maybe behind coving), to ceiling void.
Assuming just a single lighting drop, this can be smaller shorter chase where often the plaster is OK to bury a 1.5mm T&E,
90%+ of these I manage OK with my "old saw" method.. (post#3)
Really its a case of...
- Assess the wall condition for each job.. (is the plaster already coming away from the wall? if yes warn customer before you start hacking at it!)
- Length of run..
- How much mess is likely to be acceptable..
- Watch out for downstairs room that have have internal damp preventive work done, i.e. bottom 1m or so of the wall is a much harder cement mix, not your average "soft" plaster..
then select your weapons as appropriate to the conditions..
I don't think it is a case of "One solution fits all".
:coffee
