Ok, so I am an Elecsa registered sparks and in my first year of going it alone.
I have a rewire to go and quote for and although I am confident in carrying out the works, I would appreciate if there was a check list to base my quote on.
If anyone feels like posting a few bullet points, whether they are obvious or no so, that would be brillaint.
Thanks in advance guys!!
Steve.
First year of going it alone???
you don't say if it is your first year into the industry as a whole as well..
or if you have been working for a larger firm for several years previously???
If you have already been working in the industry then TBH you should already have a decent grasp of whats needed!
It could also be said that any person starting a business should have already thought of this stuff before going it alone!!
carrying out the works.. does actually also INCLUDE design.. not just cable bashing...
So I could be grumpy and just say post your existing check list up and don't be lazy asking others to do your business planing or you........
BUT...
before someone dishes out another neg scoob to me for being honest..
I will stick a few thoughts down that may help........... (or maybe not??? :C )
I am assuming you are fresh out of study with minimal experience.. few tips I would say are....
1/ When quoting for job don't get so tied up in the electrical stuff that you forget the basics of SELLING!!
1a) All the CUSTOMER wants to do is purchase a product or service.. and they DON'T have to purchase anything if they don't want to... (you are just one of a multitude of suppliers they can purchase from)
1b) So FIND OUT WHAT THE CUSTOMER WANTS.. not what you want to sell them... As with any purchase a customer is more reluctant to purchase something they don't want.. But if they are going to purchase they often like to see they have a choice to select from... so where possible suggest a basic solution plus a "for £x.yy more you could have more flexibility for the future by also fitting one of these"
2/ Don't get telling lies saying that legally they have got to have something flitted as it in the regs!
2a) BS7671 is non statutory guidance.. no one has to have anything installed by you in any property if they don't want to purchase it off you!.. So concentrate on establishing the actual requirements and the various ways of meeting those requirements.. (there is no one size fits all solution to every job!)
2b) So keep you head around the basic task in hand that you have to solve ie.. What electrical loads does the customer need to supply, what size fuses and cables to I need to install to supply those loads in accordance with BS761... AND... are there any REALISTIC additional loads that the customer may have forgotten about??
3/ Remember THE CUSTOMER PROBABLY DOESN'T KNOW THEMSELVES EXACTLY WHAT THEY WANT... they will be expecting you to make suggestions...
3a) So don't try and think of the job as one big task.. Break it down into individual rooms or circuits or major loads etc... have a few basic ideas before you meet the customer..
3b) The customer probably hasn't got that much spare time to talk to you and you don't want to be wasting your time when at site.. so have a pre set idea of what you would actually do in an average 3bed semi property, then work around that as your framework either adding to it or removing from accordingly.
4/ SO what are the basics needed for the average property.. sockets & lights of course but need to verify number of circuits you intend installing..
4a/ Find out if Electric cooker / Shower / Immersion heater / Outdoor wiring are needed...
4b/ Assume minimum of 2x Socket circiuts & 2x Light cicruts but preferable more if feasible.. e.g. up/down/kitchen(utility) sockets separate
4c/ DON'T assume sockets MUST be on a ring!!! appropriately rated & designed radials can be a better solution!
4d/ Assume 3x double sockets 1x lights switch & 1x pendant as the staring point in each living/dining/bed/room.
4e/ Suggest smoke alarms.. preferable but NOT essential!!
5/ Only get essential information whilst on site, other more detailed stuff can be confirmed IF you actually win the job!
5a/ Precise locations for sockets. is not that essential as long as you know how many per room...(Assuming you quote for getting wires across to each side of a room moving one socket 2 meters to the left don't really affect your price!!)
5b/ When discussing lights ALWAYS check where they want it switched from.. Essential to know which lights are two or three way switching -vs- single switch at door.. AND check which if any are dimmers!
5c/ Ask about any specific decorative finishes.. or just plain core white?
5d/ Get supply details, check cut out, earth type, take a Ze reading to make sure you wont have later headaches about the supply.
6/ Check out and note the building construction...
6a/ Floors... solid / wooden ? Floor coverings... carpet / lino / laminate / tiles ect..
what floor CAN be lifted and which cant!?
6b/ Walls.. stud walls / brick walls / Plaster board / lath & plaster etc...
6c/ Ceilings.. accessibility from above.. loft voids / flat roofs / artex / lath & plaster etc...
6d/ Room sizes, note down rough dimesions...
6e/ Outbuildings & external wiring.. garden lengths, / obstacles etc..
7/ ALWAYS take into account the use of the property...
Landlord renting out -vs- private homeowner same building very different requirements!
