check this pls
NWDS
Jun 18, 2008
165
Test on a 300m lenght of single core MIC produced the following results: conductor resistance 2.4 ohms, insulation resistance 40 Mohm. What will the anticipated conductor and insulation resistance values of a 120m lenght of cable.
I worked it out as follows,
300/2.4 = 125 ( 1/125 = 0.008 ) so 120*0.008 = 0.96
300/40 = 7.5 ( 1/7.5 = 0.1333 ) so 120*0.1333 = 15.996
the answers given are 0.96ohm & 16Mohm.
I have the right answer but have I used the right formula ??????
You've worked it out the long way around!
I'd have done 2.4 / (300/120) = 0.96 ohms
and 40 / (300/120) = 16M ohm
Just using the ratio! (you could simplify it by working out 300/120 = 2.5 if you want!)
You've worked it out the long way around!I'd have done 2.4 / (300/120) = 0.96 ohms
but IR increases when length decreases! so expected value would be
(300/120) X 40 = 100Mohms
Iam going to burn this bloody book. headbangheadbang
NWDS
Electrical Installation Calculations vol 1 7ed by A J Watkins & C Kitcher.
headbangheadbangheadbangheadbang
now Iam going to Guiness DrinkGuiness DrinkGuiness Drink
NWDS
the books i've got are BASIC ELECTRICAL INSTALLATION WORK by Trevor Linsley. and ADVANCED ELECTRICAL INSTALLATION WORK. amazon usually do a deal on buying both.but to be honest you'd only need the advanced one. i found during L3 a lot of the overheads that my numptee tutor would use were straight out of the advanced book.
