an update: we've got pretty much used to lamps/torchlight over the last fortnight due to a host of other problems taking priority, and while there were bigger problems around, all the best-laid plans described above have gone out of the window and none of us have sought to get anything sorted. the circuit breaker in question has been off for 10 days or so.
now i'm back on it. i thought that before i called an electrician i'd check the intermittent problem was still manifesting; i reset the breaker at 2pm today, and it has remained on without any sign of tripping ever since. so i'm a bit puzzled. the only strange thing that happened was that a bulb went out in the bathroom - i thought to myself "there goes the breaker" but all the other lights were fine. i changed the bulb and it was back in action. when i put the 'faulty' bulb into a lamp, however, it was working.
i'm not sure what to do now. advice welcome. in the background i'm working on getting the rodent problem sorted once and for all, but is leaving the breaker on a massive risk at the moment? is it still worth getting it looked at even if the symptom has vanished?
please don't reply if you're just going to have a go at me for not getting an electrician in over the last fortnight. it's been quite a horrible time for me with various things, so i could really do without it, thanks
