what about those square self adhesive jobs that you can both stick and screw to walls? you then use a cable tie to fasten the cable securely??
AndyGuiness Drink
AndyGuiness Drink
and it will have fallen off by the time i get down the ladderwhat about those square self adhesive jobs that you can both stick and screw to walls? you then use a cable tie to fasten the cable securely??AndyGuiness Drink
me, being the pyromaniac that i am, will end up with a few more problems than clips not fitting into walls!Get a box of matches and a small drill cheapest option.
With all the fire officers on here we will be ok.me, being the pyromaniac that i am, will end up with a few more problems than clips not fitting into walls!
