This sort of thing seems to be endemic to our trade .
Builder phones to say 2nd fix can be done , we'd actually forgotten about the job TBH , so go there yesterday , we'd wired a couple of lights and taken some wiring out for him . So , fit new lights ..... re-install wiring in garage and re- fit fluorescent fitting .
Existing three plate connections in fluoro with our feed running from there , switch on , it works and the new ones too .
Try the 2 way switch ...BANG ! ..trips out . "How can that happen , it was working ...must be the other strapper has a fault "
Switches off to see if a wire is trapped etc
"Hang on , one of the new LED GU10 lamps has blown , its all black ....try it now"
Power on , new lights on, great , try the fluoro 2 way , BANG ! Tripped again , theres a fault on this 2 way somewhere .
Hang on , theres another LED lamp gone . LEDS are on a seperate 1 way switch .....pure coincidence they both decided to blow as we tried the 2 way . Duff lamps supplied with fittings .
Its like some demon follows you around making $hytte happen :C
