SeánH
Hi folks,
I have to draw a labelled diagram to show a 2 core pvc/swa cable being terminated into a polycarbonate 6 way distribution board with a 100 amp double pole isolator and assume the cable is the main incomer.
My question is, which way would the cable be installed i.e. from the top/bottom etc.
If anyone could point me in the right direction or provide an example of a diagram showing the above situation it would be much appreciated ray .
Thanks in advance
Sean
Thanks in advance
Sean
