- Joined
- Dec 25, 2011
- Messages
- 5,470
- Reaction score
- 80
Felt best to post this here. I'm not sure, ran it by 3 sparks at works who all had a stab but weren't sure so here it is:
Declared single phase supply voltage can be 230V -6/+_10% so 216.6V at the lower end. Appendix F of the OSG says permissable drop is 3% for lighting & 5% for other uses. But do you assume 3 or 5% below 230V or the actual measured voltage on site at the time of test, the issue then being that that figure can vary?
In the case of say a house supplying an outbuilding you would obviously take the origin voltage as being at the house.
Assuming then that you've calculated acceptable volt drop at the outbuilding, if at a later point in time you supply a further, remote building from this outbuilding (maybe with a smaller cable) do you take the origin voltage as being at the outbuilding now? I think so but am not sure.
Hope this makes sense. Apologies if a numpy question!
