Oriole
My bathroom’s central heating towel rail has an immersion heater with an on/off switch, wired from a switched fused spur in an adjacent cupboard. I’m forever forgetting to switch it off, after having intended leaving it on for an hour only. It needs a time switch
The on/off switch is a short tubular unit that connects to the bottom inlet of the towel rail via a tee connector. The ideal solution would be to be able to replace it with a simple time controller, if such a thing exists. I suspect thought that the switch unit and the immersion heater are one composite item, so I would have to replace the lot.
I’ve come across another option: A Horstmann Electricsaver or a Kudox Wall Controller.
Does that mean I could do without the fused spur?
- Does anyone have experience of either? Are there good reasons to choose one rather than the other?
- Either of them could be conveniently installed in the back box that houses the existing switched fused spur, though that would leave nowhere for the fused spur. Both instructions say a fused spur is necessary on the supply side, one preferring in addition a separate supply from the consumer unit.
