I believe the regs say you can't enclose connections in a wall e.g. inaccessible location. Is it ok to do so with maintenance free connections, e.g. crimps?
What do you guys usually do if you end up needing to extend a cable, say half way down a wall where you don't want a blanking plate to end up.
I got the end of a reel of cable yesterday and had run the cable all the way through the house and it was short by about 3 meters. So I crimped and extended where it will be plastered over.
