Is there enough carlsberg ?
Doubtful,
Is there ever enough,?
Good job its not at a different angle, :slap
Don't get too cocky Mr Duck,
I may need you for the marquee design,
Not got a wipi,
Have to get an rj45 on the back panel for updates, and a USB for new games,
Doing a vertical this time,
Hopefully get the case finished this weekend, ( although the NW200 may slow that somewhat )
Then the wiring to sort,
Just need and ide cable for that, I have the code mostly sorted, just need to check its all good,
Do some "secret" holes for the on/off switch etc,
The TV controls will live on the back panel in case volumne etc is ever needed easily.
Is it wifi enabled so we can all play :facepalm:
if Carlsberg did slot cutting in plywood.....
I think it helped, if it had done it on its own it would have been done properly,
:slap
Still need to source some pink or purple T moulding, nobody seems to have any, :C
