grumpygrandad
[SIZE=medium]I recently fitted led daylight running lights to my Nissan Juke. For the picky, because I wanted to. The controller was the second generation sort you connect directly to the battery. It turns on the drls when you fire up the engine, and shuts them down 15 seconds or so after you turn the engine off. Very simple to fit, but there is a problem. The controller works by sensing the initial voltage drop when the starter motor draws current to turn over the engine, and turns on the drls. When the engine is turned off the battery volts drop to around 12 and the controller senses the drop and shuts off the lights. The Juke has a system for charging the battery which means that it is not always charging. When the battery is fully charged the alternator stops charging until the volts drop below a preset level. Trouble is, the drls think the engine is off and shut down. Ho hum.[/SIZE]
[SIZE=medium]I have thought of all sorts of ways to get round this, but I can't think of one that will work. Yes, you can wire into a spare fuse position which is live when the ignition is on so the lights come on and off with the ignition switch, but that simply bypasses the controller. Has anybody fitted one of these 'second generation' controllers and got it to work without being switched off by the 'smart charging' Juke system, and if so, how? Please!! It's driving me and my car mechanic son in law nuts.[/SIZE]
