Dc Fire?
So why when we have perhaps HV d.c, supplies is there not a requirement for a "Fireman's" switch affair to split / break the string supplies to reduce the d.c. Voltage?
Nothing to say the fire was started by the solar pv system.
BUT the fact solar pv was present means the FB won't enter the roof space so their efforts to tackle the fire are entirely from the outside.
A warning to others with PV, don't expect the FB to enter your roof.  I can see insurance premiums rising for properties with solar PV?
I'm glad my panels are on my garage roof not the main house roof. If I have solar PV at my next house it will almost certainly be ground mounted (there are a lot of trees so would be major shading issues with a roof system)
I can see fireman's switches (on the DC side) being required before long,,,, possibly?
Before logging on & reading here, we in the office were discussing the issue of isolation in the event of a fire (external switch).
Property is golf club, so almost certainly 10kW minimum. Even with firemans switch the panels are still live. Will be very interesting to see if local news reports the actual cause of the fire. As Dave said, it may well be something non-PV related, but I have seen rumours of cheaper panels causing fires ie Suntech (now defunct) from the USA, and those panels look like cheaper units - you can tell by the amount of white backing sheet that is visible).
One bad practice I see is relying on DC switch in inverter - they tend to be tucked away underneath unit and not clearly visible. Knocking out AC should shut system down anyway, but a clear DC isolator is still very useful in my opinion. Either way, it only takes a simple poor connection in any part of the DC chain to cause issues. Having once managed to cause a dc fire at an inverter I was changing (pulled connection without tuning DC off) it is quite scary how DC propogates a fire, but that was on a string carrying 800V. Think in future I might go back to multi-stringing arrays to keep voltages down and half the power behind any faults.
