Defined scope part p
buttonit
Nov 18, 2009
9
Hello, can anyone tell me, what you can actually do on a part p defined scope? I have looked everywhere to try and see what you can actually do, but with no joy. ie, can you add lights to a circuit, and sockets on a ring final etc. Thanks.
I think defined scope is for alarm installers that want to add a spur of ring main and gas installers that want to install ch controls or put a spur in for heating system supply. I don't think they are allowed to add extra circuits.
nic web sight had got it all defined
Pritty much minor work I think
Just ploughed through my ELECSA stuff but it doesn't say.
Pretty sure its for Kitchen and bathroom fitters to alter and add to wiring but not install new circuits . And Heating fitters to wire up boilers , I assume.
Someone will know, keep looking.
itll be linked to the trade of person - i.e kitchen fitter would only be allowed to work in kitchens, heating installers only allowed to install heating controls etc
Part P Defined scope, is trade limiting.
For instance if you fit kitchens you apply to move or replace sockets/cables in the kitchen.
You are not allowed to fit a shower, wire the boiler in, or change the cu, unless your the gardener !
(last bit my joke).
The whole idea behind the defined scope was to allow trades that require minor alterations or works involving electrics could do so without the need for a qualified electrician to do it for them.
However this defined scope has been greatly abused, and I have heard of instances where some have done full rewires etc etc.
Thanks, do you know if you can fit lights in bathrooms, like for instance, changing the one main light for several downlights, permitting you dont overload the circuit, and install extractor fans? I am at the moment getting in touch with niceic, and all the other bodies.
From the sounds of it you would like to be Part P registered.
The works you describe do not come under the Defined Scope registration.
Any work that requires reporting to your local building control, is governed by Part P of the Buildings Act.
The most obvious, is areas defined as special locations ie:
Garden/Outside installations
Kitchen
Bathrooms
Then there are the reportable works such as:
New consumer units
Installation of new circuits
amongst many others.
If you want to carry out any of these types of works then you must be fully registered as a Part P installer (DI).
ELECSA Defined scope;
http://www.elecsa.co.uk/schemelevels.aspx?SearchString=DEFINED SCOPE
NICEIC Defined competent part way down this page;
http://www.niceic.com/en/contractor/article.asp?SECTION=15&ARTICLE=9
NAPIT Have a bit here;
http://www.napit.org.uk/qualsElec.asp
and another bit in FAQ here;
http://www.napit.org.uk/membership.asp#13
Some more food for thought Buttonit.
