Hi to you all and I hope you can help with this problem.
I have a Delonghi ECOV310 which when heating the water releases loads of steam through the nozzle.
As at a guess it doesn’t seem to be holding the pressure so as the water heats up it releases it?
my question is were is the valve which holds the pressure on these machines as I cannot seem to see it. Is it inside the boiler?
any help in this matter would be greatly appreciated
paul
paul
