I have a problem that five electricians so far have been unable to track down.
I have a four bed detached house. Consumer unit is a wylex 16th edition, split - 100A switch and 30mA/80A RCD. We're getting truly random trips off the RCD. The source is the ring main. The RCD has been tested and cleared by all five electricians - if anything, it's on the slow side of acceptable rather than being twitchy.
We were advised that it must be an appliance, so we should try isolating all appliances and gradually re-introducing them to see which caused the trip. As best as we can (it's the ring main...) we've done that. No single device or pattern of devices causes the trip. Sometimes we can go weeks without a trip, other times we'll get a dozen in a single day. Last night it tripped when my wife turned the kitchen lights on, even though they are on the mains switch side of the box and not covered by the RCD at all. This morning it blew when I turned the kettle on (twice) but when I moved the kettle to another socket it was fine.
When the RCD fails, we flip the ring main 32A MCB off and the RCD will reset fine. The minute we try to flip the MCB on, the RCD trips AND the MCB fails. Yet if we persist with the MCB (yes, I know...), trying to set it occasionally over the next 10-15 minutes, it will eventually turn on again. It will then run for anything from ten minutes to 10 weeks with no change whatsoever to the loads.
I'm not an electrician but do have C&G 2381 (16th edition) so I'm not a complete novice. However, this one ash me stumped. I don't even know who to call for help. Any suggestions?
