Thanks Monkey, They’re normal lamps, I had the 3 earth’s so I earthed the one that comes with the live? Is that alright?Have you got leds or normal lamps? Also, if it's a metal face plate it needs earthing.
All earthed, thank you all so much, I am not being a tight whad not paying for a sparky, I really enjoy learning and doing something that isn’t work and boring stuff, so thank you, always appreciated!As mentioned ALL three earth wires still need to be connected to each other...
As if you split them you may break the earth continuity to other parts of the circuit.
e.g. metal fittings in another room become un-earthed..
A lot of dimmers do have some level of buzzing while in use,,,
which can also appear worse in some hollow stud-walls, as they can become a bit of an echo chamber.
