You are correct that not all dimmer switches work with all types of light. If you are considering dimming any low energy type lights such as LED's I would suggest checking with the lamp manufacturer if there are any special dimmer requirements, as it could turn out an expensive fix if any lamps or dimmers get damaged. e.g. from an Osram webpage http://www.osram.co.uk/osram_uk/tools-and-services/services/dimming-conformity/index.jsp they pass the responsibility onto you checking the spec for individual products.on a slight tangent, I`ve been told that if I replace normal bulbs with dimmable LEDs, I will need a special type of dimmer switch? Is this necessary?
It can be the case that LED's are to small a load for the old dimmer to work correctly and you can get a flicker effect similar to when you have insufficient load with traditional GLS lamps off a dimmer. The days of simply getting a dimmer with the correct wattage for the number of lamps connected have passed. Going back to den123 original question, it is impossible to answer without verifying the types of lamps you want to dim, due to the reasons given above.LED lamps can be dimmed with a multitude of leading edge or trailing edge dimmers available on the market. OSRAM provides a list of suggested dimmers for each product. You can find this list in the technical information sheet on each product side in the product catalogue.
Some LED's, depending on their internal electronics, will specify that the dimmer must be leading edge or trailing edge, just check the manufacturers info before you specify one.on a slight tangent, I`ve been told that if I replace normal bulbs with dimmable LEDs, I will need a special type of dimmer switch? Is this necessary?
whats the best price for 2 dimmer switches white 2gang 1 way
thanks for the replies everyone - So I`ll check manufacturers info.
Can anyone explain to a thick plumber what leading and trailing edge dimmers are?
