restive loads are where current is used to create heat or light etc
different dimmers types, could be the difference between the ones that click on and the ones that rotate. the ones that rotate on will increase voltage as it rotates. the click on ones will click onto whatever voltage the dimmer is set at
"An alternative to the leading-edge dimming that is typically used with SCRs is trailing edge dimming, where the falling part of the waveform is cut rather than the rising part. This is most often used in devices that use a switched-mode power supplies that need the front of the waveform complete so that it may cut itself."
Thanks Springy , I'd read about that somewhere but couldn't remember what the hell it all meant . ( Don't think I do now TBH ) Much prefer a dirty great coil of resistance wire in series .
