Now, I have seen a few fluorescent lights overheat starters & ballasts if left energised for a long time (say perhaps even continuously) which had failed to light.
I have seen a couple of double fittings that had overheated when being in use for say around 10 hours per day average for say 5-8 years with one of the tubes deliberately removed to "save energy".
I have also been told by old hands that this can and does happen, with Fluoro's and other types of discharge lamps such as Metal Halide, Sodium etc.
I can also recall a street lamp near home (SON) which had been out for a few weeks one winter, spontaneously catching fire one night.
Is it due to the failure to light?
The one with the missing tube obviously could not light the tube, so no current flow through that side of the fitting, but, it still overheated.
Now I cannot be sure, though if the damage was done prior to the tube removal.
I did get a call to a large well known Builders Merchants a few years ago where there had been a Fire Brigade attendance to a fluorescent light catching fire. That again had been used for say 10 hours per day average, and had been out for a few months, don't know if it was due to lamp, ballast or starter though, and I can't recall if it was HF either, so perhaps no starter even!
Is this just another urban myth of the industry or is there some science or proof behind it?
Does anyone have any thoughts on this please?
