Charlie_169
- Jul 3, 2012
- 6
- 0
Hi guys, new to the forum and hoping I can gain some useful information to help me out!
I have just put in a distribution circuit into a garage, with the following specs:
6.0mm cable, 3m in length from consumer unit to new installation.
B32 circuit breaker in the consumer unit to the distribution circuits.
30mA RCB in the garage unit
B6 circuit breaker in garage unit
B32 circuit breaker in garage unit
the existing consumer unit is a 10 way split board, containing 2 30mA RCDs. I have moved the first RCB from the main switch to allow space for a single B32 circuit breaker. Reason for this is to ensure that the other two breakers aren't affected by the garage circuit.
The issue here in arises! There is power to both the consumer unit and the new distribution circuit. you fire live the board and the distribution circuit. Go to turn the garage light on and it blows the RCB in the house consumer unit. the garage lights and RCB's are fine.
The continuity tests all came back OK and the insulation resistance tests all came back at <999M ohms. I'm thinking its something to do with where the power is coming from in the board. at present it is coming off the bottom of the main switch, and the neutral into the first neutral bar (attached the RCB1 in the house consumer unit) and the earth is attached to the main earth electrode.
Any help is much appreciated! Cheers guys!
Charlie
Charlie
