Hi all!
First up - I'm not an electrician, this is purely DIY. I have a *little* bit of electrical knowledge (degree in computer networking) but I'm not a qualified electrican or even one in training - please be aware of that when replying .
So the situation is - My bathroom has a light, an extractor (which comes on / goes off immediately when the ceiling pull-switch is pulled; it's not on a timer), and the extractor also has an isolator switch.
My bathroom was not wired with power/shaver points and I'd like to add power to the bathroom, as safely as possible obviously.
My first thought was to simply run some 3-core mains from *before* the light switch (pull switch) and put that into a waterproof box.
The issue is that I cannot figure out how the wiring here actually works in terms of what lead goes to where.
I've looked inside the pull-switch rose and while earth terminates inside the switch box, live and neutral go through a simple switch to break the circuit. I'm concerned that my original plan will just leave mains on to the light/extractor all of the time and I'm trying to figure out which cables actually go where so that I can figure out the best place to run a mains lead from.
Ideally I want the mains power that I'm running to be "always on", not affected by the switch or isolator, whilst letting the light/extractor fan still function as intended.
I have a diagram of what I can currently see (solid lines) and some guesses at what is going on "behind the scenes" (dotted lines) as well as before/after diagrams.
There's also a photo of the inside of the light switch - the only "exposed" part of the mains here that I can easily get to
I can't post those images here but I've uploaded them online if you want to see: https://imgur.com/a/EopVdxY
Essentially what I had is three places that I could potentially take power from - The switch, the light or the extractor. I figured the switch is the only place where there should currently "always" be live mains. My plan was to replace the current pull switch with a junction box that would go back into the pull switch (which would be moved to next to the junction box), but *also* split the power here into a second mains lead and put that into the back of a waterproof box, to hold the plug etc. See diagram
My questions are - would this work? How is the mains likely wired through my switch/light/extractor? And what would be the best way to achieve what I'm trying to do.
Thanks!
Thanks!
