First post here so bear with me, this is by far the most helpful forum I have found and great that it is UK based.
I had the expensive outline prices from installers and then when I told them I did not want grid tied they said they could not install anyway.
From this outcome I have decided to do the install of the solar kit myself.
I am fortunate my daily usage is never more than 5 Kw and this is due to reductions in sizes or appliances and lighting changes to l.e.d. This means I do not need such a large array or storage, never the less I am hoping to get a 5000 watt ready build system and add 2 of the 5.5 Kw h lithium Ion batteries.
The only question I have is this. If I supply my power hungry appliances from the solar/battery system (My hot water is from solar thermal I have recently installed) and still keep the mains supply as a backup how can I connect the backup power input to the inverter for charging the batteries on cheap rate electricity overnight from my mains supply to the house.
Do I need to have a separate consumer unit fitted or can a supply be run from the now redundant economy seven consumer unit that was used to power the 5 storage heaters in the house? All of the storage heaters were 2.8 kw so they all have the same circuit 15 amp protection in the consumer unit. My proposed inverter has a Max 60 amp backup input rating which I will not be able to get anywhere near to, but I want to ensure that if it takes power from the main supply it will not overload the cables from the consumer unit
any advice would be very welcome please. PS I realise getting an electrician in is a long wait but that is something I can live with if I get a decent one.
regards tony
Split and slightly edited as it was hi-jacking another thread
regards tony
