Domestic Inspection and test - EICR
sparky2504
Jan 31, 2012
13
Hello Guys
I have a question i'd like your views on if you don't mind.
Carried out test recently and these are the main details.
7th Floor Flat
TNS supply
Main switch DB.
1 General ringmain protected by 61009
2 Kitchen radial circuit protected by 60898
All other circuits protected by 60898's
All wiring for circuits is either in metal conduit within walls (less than 100mm deep)
or surface mini-trunking.
Supplementary bonding IS present to bathroom.
So, SATISFACTORY or UNSATISFACTORY.
Comments welcomed..........
:coffee :slap
What age.....?
I'd say that someone has in recent years added a socket possibly to the general ring main and has rightly so by the sounds of it installed an rcbo????
What age.....?I'd say that someone has in recent years added a socket possibly to the general ring main and has rightly so by the sounds of it installed an rcbo????
Installation approx 15 years old Fuseboard is MK and RCBO is 2 way module so i'd guess it was installed this way originally.
You used to be able to give a code 4 to socket outlet circuits in locations where outside use is unlikely, as this is a 7th floor flat
would this now be a code 3?
Installation is satisfactory I feel, just unsure if the above is still just a non compliance with BS7671 or worse?
The only reg that stops this being a C3 is the one about the installation being under the control of a skilled or instructed person - that's for both burried cables and socket outlets <20A. As this is domestic then these regs don't apply and in my book it's a C3 (improvement recommended)
---------- Post Auto-Merged at 20:45 ---------- Previous post was made at 20:43 ----------
Only C1's and C2's would make an installation Unsatisfactory
code 3 mate, its unlikely to be used outside, and im guessing there is no socket in shower/bathroom......have a look at ESC site Best practice guide 4.... Download it and away you go....
Now I`d have to say that the type of occupant could have an impact - as could the ownership & purpose of the flats.
It may be a C2 - the sockets are in the kitchen; where water and/or heat are routinely used.
I think that, dependant on circumstance, I would be hovering between C3 and C2.
Now I`d have to say that the type of occupant could have an impact - as could the ownership & purpose of the flats.It may be a C2 - the sockets are in the kitchen; where water and/or heat are routinely used.
In what situation would you give it a C2 ? Just asking.....
Right then, sorry for resurrecting this thread but I must have been asleep/not paying attention/mind on other things etc etc , so please bear with me.
Whilst enthusiastically ambling around ELEX last week I lingered by the NICEIC Miniature ampitheatre. In doing so I caught the very tale end of some mutterings by Herr Oberleutenant Cable. He was talking about filling in a Domestic EICR and in particular the lamp rating/thermal damage checks to the surroundings of recessed lights and pointed to section 7 of the Domestic EICR, which he had in full colour up on the screen. He or his minion advocated the purchase of B.U.M. Cam [more money, I digress] to view the inaccessible surroundings.
[Puts on NOMEX and awaits the Maelstrom]
So to my question, I have just been perusing the 'Large Verdant Tome' on another matter and could not see a reference to this Domestic EICR. Have I missed something? Has Mr Merlot come out to play early? Was I asleep? or am I just being 'as thick as a whale omelette'? I feel the latter may point to the truth....... :coat
---------- Post Auto-Merged at 19:55 ---------- Previous post was made at 19:53 ----------
Forgot to add that I do so little Domestic that this ,as yet, has never become an issue :Y
Right then, sorry for resurrecting this thread but I must have been asleep/not paying attention/mind on other things etc etc , so please bear with me.Whilst enthusiastically ambling around ELEX last week I lingered by the NICEIC Miniature ampitheatre. In doing so I caught the very tale end of some mutterings by Herr Oberleutenant Cable. He was talking about filling in a Domestic EICR and in particular the lamp rating/thermal damage checks to the surroundings of recessed lights and pointed to section 7 of the Domestic EICR, which he had in full colour up on the screen. He or his minion advocated the purchase of B.U.M. Cam [more money, I digress] to view the inaccessible surroundings.
IIRC the model forms in BS7671 refer to the EICR schedule (Form 7) as "Schedule for DOMESTIC AND SIMILAR PREMISES WITH UP TO 100 A SUPPLY
Note: This form is suitable for many types of smaller installation not exclusively domestic"
I think the NICEIC have done their own version of the forms, and probably relabelled it as only for Domestic. I am aware that the regs Form 4 - the test results schedule - has a column missing for number of points served, but napit, niceic etc include it on their forms.
They do like to have branded ones :)
hope that helps!
PS In the nicest possible way, what the heck is a B.U.M. cam?
IIRC the model forms in BS7671 refer to the EICR schedule (Form 7) as "Schedule for DOMESTIC AND SIMILAR PREMISES WITH UP TO 100 A SUPPLYNote: This form is suitable for many types of smaller installation not exclusively domestic"
hope that helps!
HE mentioned section 7 and pointed to about 4 or 5 lines asking about lamp rating, fire stopping of holes, connections, proximity to beams etc. He advocated removing one fitting and fitting B.U.M. Cam up the hole and having a snoop. If you remove the full stops from the B.U.M. Cam it should become self explanatory! CPC have them on offer at 68 quid plus VAT at pres.
So I take it that we are not using the model certs in the regs book but INSTEAD some that the NIC have made-up????
I have a torch and a mirror, thats always been my method, until I get a lot of money I dont need it will probably remain my method. :|
Agreed! I have 2 mirrors on sticks [dental 32mm diam and a larger 40 x 80mm]
They live in the tool box, camera when I remember it is always in the van. I only bought camera on a whim, it is handy , but not that handy....battery needs charging, cant find charger, camera gets too close etc etc
A miiror and the MkI eyeball is far more resilient............ :coat
What are your [publishable] views on my Domestic EICR conundrum? or pm me if NOT publishable!!
Agreed! I have 2 mirrors on sticks [dental 32mm diam and a larger 40 x 80mm]They live in the tool box, camera when I remember it is always in the van. I only bought camera on a whim, it is handy , but not that handy....battery needs charging, cant find charger, camera gets too close etc etc
its a dumbed down tick list to make it easier for people that dont know what they are doing to fill out.
