Hi
Have been to look at a job that involves a Meter move, from inside of house to opposite side of wall to the outside. He is speaking to EON to get guidance on this & pricing.
Anybody have any info on what a Meter resite is likely to cost?
If he goes ahead with this, I'm having to relocate CU into Hallway, again just a case of installing new board other side of the partition wall it is currently on. Apart from a few things I need to investigate further, I'm wondering on the routing of the Tails out of the DP Isolator within the Meter back into the house.
If I back entry through the cupboard & it's a cavity wall (?) best bet would be in 20mm conduit per Tail. My main concern is zoning the cable? If I came straight out & down to go under boards chased in, would this be acceptable? The zone being the meter on the outside wall?
Cheers
Cheers
