:shakehead :C Pleased for you Onoff.
What did he say?
What did he say?
Cheers, I'd heard there could be issues. Was going to follow this guide:ah,
quick tip,
partition the disc BEFORE putting anything windoze on it,
windoze has a habit of throwing a strop and going in a huff if you ask it to share,,,,,, ; |
tbh iv only tied running 2 OS with software think it was glass box but it was a while back. advantages are its easier safer and i used to jump in and out of os i used win7 and ubuntu i think. i have a high spec pc so i dont know if ur machine will or wont run fast enough for you but mine ran both simultaneous while doing shed loads of tasks in both with minimal distruption plus think you dont have to partition as suchCheers, I'd heard there could be issues. Was going to follow this guide:
http://apcmag.com/how_to_dual_boot_windows_xp_and_linux_xp_installed_first.htm
Ash, VM is fine for some stuff, but it still leaves you up the creek if the carrier OS crashes,tbh iv only tied running 2 OS with software think it was glass box but it was a while back. advantages are its easier safer and i used to jump in and out of os i used win7 and ubuntu i think. i have a high spec pc so i dont know if ur machine will or wont run fast enough for you but mine ran both simultaneous while doing shed loads of tasks in both with minimal distruption plus think you dont have to partition as such
yer, thats fine,Cheers, I'd heard there could be issues. Was going to follow this guide:
Going to ask the obvious then..............the PC is only an old P4 with a couple of gig of RAM, really just something to play with. I can easily do "something" else before I load it up with stuff. Any tips? Ubuntu first d'you reckon then?Ash, VM is fine for some stuff, but it still leaves you up the creek if the carrier OS crashes,
running Ubuntu 'inside' windows still leaves you open to all the vunerabilities of windows, and its slowness.
running windows 'inside' *nix still leaves windows open to all its vunerabilites, but keeps *nix safe.
VM is fine and has its place, but, for a truly proper experience on an average machine DUAL BOOT is much better with a shared DATA partition.
yer, thats fine,
the big risk is in the shrinking of the windows partition, you can sometimes corrupt the windows install. :|
Scoobed. Always wondered what's a good "split" etc. What is "home" exactly? Media is obvious.partition first,
decide what size you want for windows,
then decide what size you want for data/media,
then the remainder set aside for ubuntu, say maybe 10G for / then make some for /home
eg, 100G HDD
XP needs a minimum of 20G, so prob 30G to keep it happy, then ubuntu, 10G for / and 20G for /home
that leaves 40G for /media that you can share between both Ubuntu and windows,
BTW, you can run ubuntu without /home if you want, but its useful to have at least even a small [2G] /home partition ,
oh, almost forgot, ubuntu needs a /swap , make it the same size as your RAM for best results, some say x2 RAM, but unless you need to hibernate its not needed to be that big.
oh, once you partition, install windows first on its partition,
if you install ubuntu first windows will most likely overwrite the grub loader for ubuntu,,,,,,,,,,,
true supose it depnends on the use. i only used it because at the time i was doing a com sci course and needed to use diff os's and learn how to use there com lines etc. didn really notice any slowwing but at the time my pc was top spec still a good one 3yrs onAsh, VM is fine for some stuff, but it still leaves you up the creek if the carrier OS crashes,
yer, thats fine,
