Hi all,
Another 1st project after i did all the lights in the lounge, hall and bedrooms - thanks to those who helped on that post.
Bit confused with this as firstly, the new fittings have no indication anywhere of what is the neutral wire and what is the live wire in the unit. Does it not matter when wiring to the ceiling? Surely i do not have to undo the sealed unit to see if they are coloured?
The new unit does not come with a transformer, so should i remove the transformer from the existing fittings, or use the fittings that are in place and just add them to the surrounds?
Next comes the issue with the current fittings (see 2nd set of pics). I have started to pull them out, and there appears to be no slack on the wire for me to access anything? I can see the screws, but not sure I can access them? Am i missing something?
Any guidance would be greatly appreciated.
Thank you.
Martin.
Thank you.
Martin.
