Downlighters a fire hazard??
A friend was moving through a roofspace when he stood on the chipoboard floor & nearly fell through it, further investigation revealed the chipboard was charcoal... There had been a water leak dampening the board, heat from a downlighter had dried the board and it was slowly shouldering away to itself.
Ironically there was no fire alarm in the property (a large hotel) as he was installing a new system when this happened!
A friend was moving through a roofspace when he stood on the chipoboard floor & nearly fell through it, further investigation revealed the chipboard was charcoal... There had been a water leak dampening the board, heat from a downlighter had dried the board and it was slowly shouldering away to itself.Ironically there was no fire alarm in the property (a large hotel) as he was installing a new system when this happened!
Just in time then.
:D
So what's the solution?
Fitting fire guards behind them?
Is it just a case of never allowing insulation to be put over them or are there other things that can be done to make them safe?
Any advice would be appreciated.
Thanks.
