- Feb 5, 2009
- 5,612
- 0
I'm going to look at a job tomorrow which is putting in 6 downlighters in an upstairs bedroom (loft above).
The current ceiling is being overboarded then skimmed and I've got to fit downlighters after.
1) What downlighters are best as the ones I've used in past will only fix nice onto a single plasterboard? Any advice
2) The insulation used in loft is very old which has been poured between the joists ontop of plasterboard. It's like sawdust tbh but is not flammable as owner took some out in garden and tried to light it when he moved in in 1982. He doesn't want this insulation pouring through the downlight holes when he changes bulbs. He spoke about fire hoods but I explained these are not needed and would work out expensive way of doing it especially when they're not needed. I said a plasterboard box would be better or old clay flowerpots. What do you guys recon?
Thanks in advance for any pointers/advice.
Cheers
Matty
Cheers
Matty
