green-hornet
Distinguished Member
- Joined
- Feb 25, 2009
- Messages
- 3,741
- Reaction score
- 0
I have used the aurora range recently not badly priced.
The 3 watt led's I have fitted have internal transformers, so connect directly to a normal gu10 fitting but are slightly longer, but not as long as the megaman gu10.got to be some way of dimming them. LED's only work on DC, so should be easy for manufacturer to allow dimming control on DC side?
Well not everyone seems to know what LV is12V is ELV even the veterinary knows that240V is LV
Distribution voltage is high voltage
so what's just plane old voltage?
well to be fair, a sticker sayingWell not everyone seems to know what LV is http://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Downlights_Index/Downlights_Low_Voltage_1/index.html
It is confusing but people tend to call 240v ones mains voltage and 12v ones low voltage although they are elv. If you said to someone 240v was low voltage that could be dangerous.Well not everyone seems to know what LV is http://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Lighting_Downlights_Index/Downlights_Low_Voltage_1/index.html
i hope your using holders designed for 65W!im using 12V alot more now since i can get hold of the 65w IRC lamps, gives a bit more light where existing downlights arnt bright enough. Havnt seen any 65w IRCs in GU10 yet.
I always go for the cast twist-lock fittings from Denmans (Aurora I think) - price negotiable on quantity, will accept CFLs and just a generally nice looking fitting when mounted to the ceilingwhile we are on the subject, anyone want to recommend some decentish cheap 230v downlights, I need about 20 for a garage cum gamesroom. brushed chrome or similar.
The soft start of the transformer electronics helps to extend the life of these lamps.i tend to fit the 240v ones over the 12v because of the amount of transformers i have changed over time but i was told by another sparky that the 12v bulbs last longer tho , i do seem to change a lot of gu10 bulbs alot aswell! (50w)
Definetly seem to be more reliable, but GU10s have improved a lot since their first arrival.i tend to fit the 240v ones over the 12v because of the amount of transformers i have changed over time but i was told by another sparky that the 12v bulbs last longer tho , i do seem to change a lot of gu10 bulbs alot aswell! (50w)
It will happen but first the GU10 energy saving bulbs must improve first, come down in price and be possible to use with a dimmer, I knoew that the dimmable exist but they are stupidly expensive.Unfortunately the option of fitting gu 10 halogen lighting will be removed from us all shortly they are so inefficiant that they could never give the required minimum 40lumens per watt.
Got plenty of these in my house now, incredible lamps. Just wish they would warm up a little faster.I use 12v as you get more light for your money although these days I tend to opt for 11watt megaman gu10's usually unless customer specs halogen.Batty
The description used is 'Dimmerable' it really annoys meIt will happen but first the GU10 energy saving bulbs must improve first, come down in price and be possible to use with a dimmer, I knoew that the dimmable exist but they are stupidly expensive.
