Electric_Yoda
- Oct 21, 2008
- 15
- 0
Hi guys
Question as title. Just wondered what yr preference is ?
Cheers
E_Y
Cheers
E_Y
Yep. Plasterers are plasterers though, some will fill everything, some won't. You could use one of the box cover type things, although that's expensive, although it doesn;t take long to knock any excess plaster out and run the tap through the lugs. Private jobs I tend to find the plasterer will be half decent at not filling the box, on sites and larger contracts the plasterers don't seem to give a ****.Same old problem with plasterer filling the box though.
And then you can't hear Admin 2 nagging?Cover the lugs with a piece of Insullation tape.Works evey time for me.
Why not fit the box level in the first place? Even if it's not perfectly level I've never had one so far out that I can;t level a socket up on it after.If you put the box in before it gets plastered you may find iit hard to level the socket up because the flange will be plastered in.
I've always done them after, then got annoyed that the box and the accessory were different shapes and it didn't look as good as it could because the lip of the box overlapped.Before, the lip gets plastered in and the accessory sits flush with the finished wall surface. If you fit it after there is a gap between the accessory and wall. Also, more chance of cracking finished plaster if you do it after.
Quite common really, loads of new builds with dry liners installed before. I've personally fitted hundreds\thousands. Refurbs and private jobs maybe not so much, it would depend on the job and plasterer.current plasterer prefers it and has never come across pre plastered dry liners installed.
Now I always used to do this, saves raised heart rates at second fix stage, but a couple of plasterers have moaned as the plaster slumps on the edges, more so on the downlighters due to gravity. Partly down to the way the trowel sort of sucks the plaster off on the way over the edge, partly down to the fact that the excess gets pushed in the hole so there's more weight on the edge of the hole whilst wet which pulls the corners down. Makes sense, but then plasterers are generally an odd bunch so **** 'em.if you don`t want to fit the box; at least cut it out first - same as downlighter holes.
