If you are Gas Safe registered you are not a plumber.gas safe plumber
Nor are you by default an Engineer!!!If you are Gas Safe registered you are not a plumber.
I certainly do. I try and avoid calling myself an engineer as I am not, however I do work with 2 electrical engineers.Nor are you by default an Engineer!!!
I'm sure you know that too Lurch!
I had seen it mentioned once or twice!I am though Lurch, & I studied long & hard to gain that recognition, and it anniys me the way the title is belittled!
I do bothIf you are Gas Safe registered you are not a plumber.
I once started to wire the WRONG house on a new estate....wrong builder!I do both
I don't call myself an engineer though.
I remember a gas safe trainer at college saying
"Engineers work to the nearest millimetre, Architects work to the nearest centimetre and Plumbers work to the nearest room."
traced the fault to the central heating system
