Personally I don't think the oil tank rod was necessary TBH ,just a bond where the oil feed enters the house .
However if you ARE having a rod at the tank a nut & bolt through the clamp would be a good addition.
Regarding the RCD test button ... I've found quite a few where the test button doesn't work but the tester knocks them out with no problem .
No idea what the rod on the oil feed pipe is there for .
