Yes separated
The coumn root is often insulated due to coatings, these days a polymer based coating, it used to be bitumen or similar.
If you look at the latest version of the IET “Guide to electricl street furniture” in para 2.5.2, that it is perfectly acceptable for a DNO TN-C-S supply to feed a single column, or feeder pillar.
If the feeder pillar then has distribution from it, this must be TN-S, but, additional means of earthing are not needed , over and above a means at at the feeder pillar with a recommendation only to add another means of earthing at the ultimate or penultimate column in the radial circuit.
no you cnat use that mate jeeeez this is why people like you should be shotyou can use TNCS for street lighting, so cant see any issue with TNS....
Oh dear, this won't end well, just how much experience have you got my friend, you've got some pretty big balls coming on here and having a go at some of our most respected members.no you cnat use that mate jeeeez this is why people like you should be shot
Really!no you cnat use that mate jeeeez this is why people like you should be shot
