EDF Earthing
- Apr 17, 2010
- 14
- 0
Hi, I have recently had an earth loop impedance problem identified and the DNO has offered no help. My electrical knowledge is at best rudimentary so any advice would be gratefully received.
In 2006 the house was divided into 2 flats, our contractor did everything up to the fuse box, EDF upgraded supply and took care of everything outside of the fuse box.
We were left with TNS incoming supply, an earth clamp on the sheath and earth from here to the fuse board.
A couple of days ago we had an oven and hob installed, following installation the electrician tested the Earth Loop Impedance and found it to be 2.77Ω, he went to test the ELI at the supply and found it to be 2.65Ω, at one of the sockets it was 5.6Ω. Our electrician advised that this results from 'insufficient earth path' and is a potential danger.
He advised that we contact EDF to arrange PME as he did not think TT could solve the problem.
After hours on the phone and a dozen different stories EDF have advised that we are responsible for earthing the supply and that PME will require a new service cable at an anticipated cost of
