Gina
Active member
I will let you all know what we sorted.. I will take your comments onboard and ask the electrician to do / check what's mentioned here!
I start liking wires now..![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This circuit got 4 plugs in 2 different bedrooms and one fusebox in upstairs cupboard in which there are the wires connecting this heating zone controller device.It is possible to trace and check the cables with the floor down, it may be a little more difficult to replace if damaged part at through.
A person who is good at determining what the readings on the meter are saying is required, if the electrician only records the results but does not understand them then they are not best placed to advise.
Many faults of this mature are a result of human error or faulty appliances, unless you have a vermin problem.
makes you wonder if it's a cable just under the floorboards, or possibly a nail just touching the cable that moves with people walking up and down.
As it is suppossed to be a ring, it should be possible to identify and isolate the faulty length of cable and split the circuit into 2 separate radial ccts, RCBO will need changing to 20Amp and not left on 32Amp.
This circuit got 4 plugs in 2 different bedrooms and one fusebox in upstairs cupboard in which there are the wires connecting this heating zone controller device.expand...
Sounds like a knackered socket(s) in the bedroom, or incorrectly wired sockets which could possibly explain why your sparky didn't find a fault as cable testing doesn't necessarily reveal such a fault unless every point on a cct is inspected. Only testing/fault finding will answer your question properly.This circuit got 4 plugs in 2 different bedrooms and one fusebox in upstairs cupboard in which there are the wires connecting this heating zone controller device.
Luckly the fusebox we could take it out completely and plug the wires from the heating 2 zones controller at a 2 sockets plug next to the fusebox.
So, the fusebox upstairs in the cupboard, independent to the consumer unit new installed, is disambled/out.
But I wonder now, the tripping came from the one bedroom plugs. If we disconnect those 2 tripping plugs complety, could it be possible that the circuit will be working fine for the next 2 plugs in the other bedroom? Meaning the fault could have been the 2 plugs which tripped a lot in the one bedroom?
Luckly again we have a third plug on a different working circuit in this bedroom, but we would need one plug for the second bedroom.
Tracking cables is too late now as we fitted new floors...
He came and checked the tripping before the floors went down.. He said is all good. He had other small bits on his list to fix, from the day he teasted the new CU.. I never imagine the situation will turn like this. He could have test it properly, as I am sure at this day, having other bits he just did the quick test with the plug in 3 lights socket and he saw 3 green lights, assumed it's all good. He was first contacted by us in the beggining of November.If you had tripping before floors went down ,it makes me wonder why flooring went ahead?.
Seen many pressure faults occur with flooring laid on top of old floorboards, it happens! .
Please try and be nice to your spark and he to you i hope , see if he can be worth his salt and trace the fault . Its not rocket science and would be wrong of us to assume he is not competent as only you and he know the full story.
No offence intended or implied to either party...
We are consumers, we employ traders to do their job.Floors down after initial tests!
I'll say this again - communicate with the spark, WE are only speculating.
The electrician should have done his, especially he knew we will have floors done. When you say you finished the job and you will issue a certificate, what we should have beed waited for?! Apologies but I don't understand the phrase
"Floors down after initial tests!" We were not told to wait with the floors!
We approached him almost 3 months ago, he took his time to come over and we had patience waiting.. I mean we did not employ him a week or 2 before the floors.. we got the house back in May. People try to fix their house and move on with their lives, don't they? Or at least that was our hope.. living in a mess is noone's desire. And we just do the essentials, not luxury, extentions etc.
So, close to zero readings would be ok for continuity checks but what Insulation Resistance checks were done as these need to be above 1MΩ as an absolute minimum and close to zero would be a circuit that couldn't be connectedWhen we told him about the tripping again while floor fitters were here, he came but the floors were covered already where the wires would go.. he tested at the CU and I went to see what is he doing and showed me the L and N were 0.4 or so, close to zero, so were good.
But the earth was showing 99.
He didn't issue anything yet.You have previously suggested the spark IS coming back. If not then you need to find another
With respect to certification and part P - have you received anything?
No, we paid him everything he requested. We paid including the testing and certificate of the CU. So, in fact we paid more as he did not provide certificates and the testing.. that's why I am here.. as he said he tested, but only he knows how..Do you owe him money?
He was recommended by another trader (I will not detail about that as well). we didn't check qualifications.Well, he’s got your money …,
Has he claimed to be a member of the NICEIC or NAPIT ?
what he will say... let me guess, "yes, I did all the testing, bla bla bla" What do we know? The reality.. Certificate hopefully will follow. I will be back when or if that happens. All the best to everyone, I know we don't live in a perfect world.You need to ASK HIM about testing and the certification
