Not good!!!!
Has your one got the DP symbol or the SP one??
john..
john..
MEM did & Eaton do the same.It is odd having SP legend on the switch. originally I thought half of it had been erased, the ink is a bit faded. But the second looks more defined.
What is the requirement for labelling of the switches?Fiils you with confidence switches with the wrong symbol on them...
So you have absolutely no idea then.The requirement is presumably that the labelling is correct.
Does the BS EN in question state what is required? Oh, you've already said you don't know.How can something be bsen approved or CE marked [if that is required] if they cannot even get the symbols right.
So what standard exactly is it that states that a full diagrammatically correct technical schematic of the devices function should be stamped on the front?Ok, you yourself said that the standard these things were built to is 60947-3. This applies to Sp and Dp types, so it is not a question of just the numbers on the side but ALSO the IEC symbol that describes the function
I at no point said I did have any clue what the requirement was and have not said what should or shouldn't be on the switches as I have no idea.Who has no idea now then!!!
What is worrying is the reference WS102TTBox says one thing, switch says another....
http://i.ebayimg.com/images/i/252091767913-0-1/s-l1000.jpg
and another...
http://i1185.photobucket.com/albums/z346/clicon357/176%20-%20Electrics/5800e52f-5b8c-4efd-9a75-75ca2eddf569_zpse79b66f6-1.jpg
john...
had a look though the ones i have. some show DP switching, most show SP switching, but they are all DPOk, you yourself said that the standard these things were built to is 60947-3. This applies to Sp and Dp types, so it is not a question of just the numbers on the side but ALSO the IEC symbol that describes the function
john...
Not quite true Lurch, the CE marking directive is explicit in its requirements, and the LVD in its also....Do you know how CE marking works? If you did you would know that it does not require anyone to do anything...
Yeah, what I meant was that the CE directive doesn't explicitly state the technical requirements of the devices that will be CE marked directly.Not quite true Lurch, the CE marking directive is explicit in its requirements, and the LVD in its also.
So there are things that the manufacturer has to do to meet the requirements of the law to ensure that th produt is legal for sale.
Remembering that to CE mark a product against say the LVD when it does not comply, is a criminal offence.
I am not disagreeing with this, but what is this "correct coding" that you speak of specifically? What exactly should be marked on these switches? What is missing? Do not start guessing again and making things up.It is all a bit beyond me, but i would think that correct IEC marking is VERY important as otherwise how you supposed to know what terminal does what and what the function of anything is?? I know it does not apply really to these things, but IEC symbols and numbers all mean something. It is the numbers on a switching device, say a relay or contactor that tell you which terminals are part of a "pair" if you like, and what their function is, NO or NC for instance, which side is "line" side. which side is "load" side and a whole lot more.
But what is not marked correctly? Can you tell me what should be marked and with what? So far you have only spouting complete made up personal opinion and tried to call it a fact, and also a BS EN standard.If i bought stuff that was not properly marked, the supplier would be getting it straight back.
If it is a single pole switch it isn't an isolator. What is a WS102TT? What exactly says it is or isn't SP or DP? You cannot randomly issue codings based on guesswork, that is what the cowboys do. If you are doing an EICR you are testing the installation, not just wandering round looking at random parts of the installation and blindly issuing random codings on things.I think what Tony is getting at when he says "What is worrying is the reference WS102TT " Is the "TT" bit could well be taken as alluding to the fact that the switch is intended to be used as an isolator on a TT system, despite the fact that it is marked as having a solid linked neutral. Let me put it like this. If i were doing an EICR [which i do not] and i came across a TT installation with an isolator marked up as being a single pole one, it would be getting a C2 for a certainty..
It is not for me to be guessing or testing the switch function....
